Thanks for that. You are correct re the SMD parts, my point was related solely to through-hole type parts ie 1/4W and 1/2W resistors.Not true with modern thick film SMD resistors.
0201 rated 30VI was surprised how low they are rated when I first saw it.
0402 rated 50V
0603 rated 75V
I wonder with the tiny SMD parts if that max voltage is re flash over from end to end rather than a material degradation failure from voltage like with through hole parts?
Yep, and I think the majority or new through-hole resistors are all laser trimmed now as part of the standard production process. I have tested some resistors from boxes (1000) that were labeled and purchased as 5% resistors, that actually measured within about 1%.ramancini8 said:The new resistor manufacturing process of choice is carbon film, and this process does not produce 10% resistors so they are not offered for sale.
I'm only guessing about the new way they make resistors, but it's likely that instead of trying to "make" a 10k resistor by adding the exact amount of carbon film, they make it 9.5k (with a slight excess carbon) and just laser trim until it is 10k. And the same process with metal film, which (I believe) must all be laser trimmed.
