1 SPDT switch (ON) - OFF - ON to power a single bulb
Haroon Kunjappu
Joined Dec 2, 2017
I would like to use an SPDT switch to power on (maintained) a bulb or use the momentary throw of the same switch to power on the same bulb for a few seconds.I found some pin-out diagrams and would like to know how this can be accomplished and what challenges I might come across.
Application: Motorcycle Aux lamps.
Bulb: LED cluster/pod/bar etc.
Switch options:
- Contura III Switch SPDT - (ON)-OFF-ON (https://www.bluesea.com/products/7945/Contura_III_Switch_SPDT_-_[ON]-OFF-ON)
- Honeywelll1MT1-5 (https://www.mouser.in/ProductDetail...=sGAEpiMZZMvudeGI7i40XBFH6KOzE4gJHbxzMsCm6m0=)
With my limited understanding and knowledge, I am guessing it would be alright to connect terminals 3 to 1 instead of Load 2, to achieve this. Please correct me if I am wrong and also help with the right way to go about this. What I am worried about is if there will be a reverse voltage of some sort that will burn the whole wiring.
Reloadron
Joined Jan 15, 2015
7,978
You got it. Tie 1&3 together and on to your lamp.
Ron
WBahn
Joined Mar 31, 2012
33,348
But keep in mind that the momentary side will only stay on as long as you hold the switch in that position. If you want it to stay on for a few seconds even if you just momentarily close it, you will need to do something else.
Tonyr1084
Joined Sep 24, 2015
9,744
I'm not certain I'm following you. IF I got you right you're saying you have a switch that is center off. Swing the toggle one way and a set of contacts go on until you swing the toggle back to the center. Swing it the other way and it's spring loaded, meaning as soon as you let it go it returns to the "OFF" position. If so, then yes, you can tie terminals 1 & 3 together just the way I've illustrated it. And just as Wbahn said, if you want it to stay lit for a few seconds after you release the momentary side then you'll need some extra circuitry.
Haroon Kunjappu
Joined Dec 2, 2017
Thank you very much for all the replies.
Both of you got what I am trying to do. Yes. I would like to retain the power supply to the bulbs for only as long as I hold it there in the spring loaded position. If I let go, the switch returns to the OFF state and the bulbs are turned off.
So this (ON) - OFF - ON switch will work I suppose. Yay!
Reloadron
Joined Jan 15, 2015
7,978
It will do what you described as you described it. The lamps will be lit as long as you hold the switch in the Mom (Momentary) position and hold the lamp lit in the On position.
Ron
Reloadron
Joined Jan 15, 2015
7,978
Depending on the bike, make and model, they do make and market switches made to be mounted on the handle bars. On my bike they are called "spots" and I have a separate switch for the spots. Anyway, a (MOM) Off On should work out fine for what you are looking to do.
Ron
Haroon Kunjappu
Joined Dec 2, 2017
Ron
Roger that Ron. It's always nice to meet another motorcycle enthusiast. I have ordered a pair of cheap floods for now. Will use them to understand the wiring and switches and put them in place. Eventually looking to get a Baja Designs Squadron Sport driving and spot combo (1 of each) :D
Reloadron
Joined Jan 15, 2015
7,978
<Off Topic> This year I converted my headlight and turn signals to LED, and also the spots. I about choked on the cost of the LED Daymaker headlight but is does indeed make day. :) The latest addition is a 1992 Harley Electroglide which I finally have just over 6,000 miles on and for the most part it is back to factory. Friends tell me the bike is "Retro" much like me. Thinking maybe next year looking for a good, low mileage, used Honda Rebel or similar smaller bike just for the fun of it. I really like the Daymaker headlight and LED spots but saved all the original stuff.
Retired now so have to time to really enjoy riding.
Ride Safe
Ron
</End Off Topic> :)
