MisterBill2
- Joined Jan 23, 2018
- 28,460
Does the TS know anything about either sensor? How many wires it had? What connections did it have? Did it have a power supply connection? or a connection to a common???
Did the TS remove the previous sensor, or was it removed and discarded by another? (I have had to deal with that situation.)
It is entirely appropriate to request additional information from a client requesting assistance, unless you are the one who designed the machine being serviced. In addi tion, given that the client in this case has not provided the additional information it seems likely that they will not be able to implement a simple transistor circuit to effect the logic reversal. That could be a problem.
