0-100% duty cycle with 555
arvinfx
Joined Nov 16, 2011
13
I have to make a dimmer with 25% - 50% - 75% duty cycle but without potentiometer , only 3 resistor or something that connected to selection key .
It is possible?
AnalogKid
Joined Aug 1, 2013
12,221
To eliminate the relatively high current through R1 and the discharge pin, disconnect the wire between R1/D1 and DIS, and connect a wire between R1/D1 and OUT.
ak
AnalogKid
Joined Aug 1, 2013
12,221
For any periodic waveform, there is no such thing as a 100% duty cycle. A 100% duty cycle square wave is DC; the output is spending 100% of the time in one state and 0% of the time in the other state.
Why do you think you need a 100% duty cycle output? What is it you are trying to achieve?
ak
