simple auto battery charger by 555
ahmed115
Joined Dec 21, 2013
32
i would like to discuss any suggeswtions to make the project without mistake
if any friend found any thing wrong in the circuit please comment
wayneh
Joined Sep 9, 2010
18,154
The only quick thing I see is there should be a capacitor (0.1µF or so) on pin 5 to ground.
Also, is the 555 OK with 15V? I don't recall but I would be tempted to start with just 9V or so until I was sure everything was working nicely. Something that may survive 5-9V for a few seconds will go poof at 15V.
You may get more feedback if you describe the function of the circuits and ask more specific questions.
tcmtech
Joined Nov 4, 2013
2,867
The standard 555 timer IC is usually rated for 16 volts but most are robust enough to run at 20 or so without problems.
I have seen that happen in a number of circuit is where the primary 12 DC regulator IC lost its grounding connection.
ahmed115
Joined Dec 21, 2013
32
thank you for your comment
the 0.1 μf not important her
555 is ok with 15 v
the circuit charge the battery for 14.3 v and reset to allow to battery to connect to the load ( i put 10k ohm only for the samulation)
when the voltage of battery down to 9.5 v the 555 make set across pin 2 anad again charge across the charge resistance 5 Ω(u lemit it as your battery capacitance)
wayneh
Joined Sep 9, 2010
18,154
Is the relay OK without current limiting, and will the coil current stay below 200mA (the 555 pin 7 rating)?
ahmed115
Joined Dec 21, 2013
32
u must put resistance in series to take the voltage difference between the source and coil voltage
=15-12=3 v
R = 3/0.15 =20Ω
ahmed115
Joined Dec 21, 2013
32
i do not know the max current of discharge pin 7
u can use the output 3 insteade as the first circuit with transistor if aproblem happen from connection to pin 7
ahmed115
Joined Dec 21, 2013
32
this site :
http://www.sentex.ca/~mec1995/gadgets/ne555.htm
Absolute Maximum Ratings:
Lead temperature (soldering, up to 60 sec) 300 °C. Supply voltage for SE555 +18 volt. For NE555 & SE555C +16 volt.
Discharge current (pin 7) is 200mA.
Power dissipation 600 milliWatts. For the MC1455 is that 680mW.
Operating temperature range for NE555 0 to 70 °C, for SE555 & SE555C -55 to -125 °C.
Storage temperature range from -65 to -150 °C.
ahmed115
Joined Dec 21, 2013
32
important notice
u can use this circuit for auto charge for different batteries voltages not only 12 v battery by changing the power source ( voltage regulator ic like lm317 ) and changing zener diod and u can also use diod for accurate voltage value with the zener
and u can also use diod only if the voltage differnece between charge voltage and seperating voltage is afew
AfdhalAtiffTan
Joined Nov 20, 2010
120
In your circuit case,
With 15V supply, and no modification on 5th CV-pin:
The trigger-pin will drive the output HIGH when the voltage falls below 1/3Vcc on pin 8, in this case, 5V.
The threshold-pin causes the output to be driven LOW when its voltage rises above 2/3Vcc, in this case, 10V.
With proposed zener-diodes, making the relay turn-on when the battery drops below 10.1V, and turns-off when reaches 14.7V.
I can't see any problem here.
Improvement maybe on the stability of the reference voltage.
ahmed115
Joined Dec 21, 2013
32
this is my design and i am aske about any thing not normal may be u and other fried found it and so
i see that the circuit is good
with respect to pin 5 it not importanat to connect capacitor in this circuit
thank u
AfdhalAtiffTan
Joined Nov 20, 2010
120
thank u
When I said reference voltage, it doesn't mean only the 5th CV-pin.
Other than the Vcc stability, the zener voltage is highly affected by temperature, which is not good for any reliable test result.
What you've done is a crude battery plate conditioner, cycling charge repeatedly.
As previously mention, there's no flaw that I could think of, it's another creative use of 555 chip. :)
If I really need to guess, I would suggest adding a pull-down resistor each at both 2nd and 6th pins to avoid any stray charge holding the voltage.
Those zeners might need some current to flow to induce voltage drop.
ahmed115
Joined Dec 21, 2013
32
zener is affected only by volatge and have amaximum current
if the voltage of the battery is high than zener volatge it will be pass current that limitted by input resistance of the pin
thank u
ifixit
Joined Nov 20, 2008
652
Some observations:
  1. I see that the load is not connected during charging. Is that what you want? To avoid this you could use another set of contacts to switch the load from battery to 15V during charge. Of course, 15V would have to be okay for the load to handle. If the load is very small like 10KΩ then you could leave it connected to the battery all the time.
  2. The test load is very small, but if it was 10Ω then some load current drops across R4 (5Ω), which is significant. Is that what you want? To avoid this, move R4 to be between the relay contact and +15V.
Have Fun,
Ifixit
AfdhalAtiffTan
Joined Nov 20, 2010
120
thank u
It seems like you know everything.
Have constructed the circuit in real life yet?
I simulated your circuit with LTspice, and it shows that some reverse-current is needed in order to get the desired voltage drop.
But, it could be another spice simulator limitation though...
You asks us for any correction to be made, and you seems to deny every single suggestion with your fact, which is fine, but, what did you really expect?
You previously said to look for anything 'not normal'.
Now, define: what is normal to you?
I watched your video, and everything is ok to me.
You even made a discrete logic for 555.
My simulation also says it will runs fine.
What kind of answer did you expect from us?
Improvement? Flaw? Tweak?
As I mentioned before, it's one of the creative use of 555, which is feasible, and I believe the internet could appreciate you to share the circuit, but again, what did you expect from us?
I'm blurred...
ahmed115
Joined Dec 21, 2013
32
Some observations:
Have Fun,
Ifixit
it is good idea to make the load connected to the supply during charging and also good idea to make the charge resistance out of battery durring loading
thanks for your good suggestions
ahmed115
Joined Dec 21, 2013
32
I'm blurred...
if u can added more improvement i will thanks for u
