I am trying to get a small digital kitchen timer to latch a relay. The timer is powered by a 1.5v battery and emits sound via a piezo buzzer. I have removed the piezo and brought the piezo drive wire and the ground (which was wired to the piezo out. When the time out is reached the piezo receives positive pulses for about one minute. I want the first pulse to latch a SCR which then holds a relay. The supply voltage is 30V.
The problem is that the 2N3904 is not switching when the piezo pulse gets to it. I think I may have the 2N3904 biased incorrectly.
I will appreciate any help or advice.
