Hi Im a newby to electronics and have a problem. I cant put an image on here of it so Ill explain what the circuit looks like.
There is 5 resistors and 2 voltage sources. The Resistors make 2 T's.
Going from left to right:
A vertical Voltage source of 43,
A horizontal Resistor of 5,
A vertical one of 9,
A horizontal one of 4,
A vertical one of 6,
A horizontal one of 2,
A Vertical Voltage of 2
Q1). To find all 5 currents through each resistor do I just use I1 = V1/R1 etc
Q2) When I1 divides into I2 and I3 does the result of I3 divide through I4 and I5
