Thank you. How do we find the transfer function the this sensor to be able to find a suitable filter. How did the filter embedded in the sensor been able to filter the input signal to this sensor?Interesting device, but precious little application info on the web. Datasheet and 'training guide' attached.
Now to your problem... the thermopile outputs approximately -3mV at 0°C and +10.5mV at 100°C. Assuming a single ended ADC at 3.3v you need to amplify the voltage of the pile by about 200 - 240 - this is probably done with a small fixed amplification in one stage (say x10) and a following stage (x24) To get a resolution of around 2°C you need to reliably detect a 75uV change allowing for noise and opamp offset. That means you need to start by finding an opamp - or more likely an instrumentation amp - for the first stage with a low noise figure and sub-10uV offset. The device has a noise figure of 0.5 √nW/Hz so your amp will need to be in the same or near order of magnitude. This isn't going to be a common hobby op-amp on a breadboard if you expect any degree of accuracy or repeatability - PCB layout will matter too.
I don't have time right now to run the numbers...
Mod: Link to old thread.
https://forum.allaboutcircuits.com/threads/ztp-135sr-temperature-sensor.188546/post-1755017
