Are there any other solutions? I suppose you could design something using a transformer where a buck converter has its inductor, but that fits in pretty much the same mental "box" for me. How else could you provide such a large amount of current?The most efficient solution is a buck DC/DC converter.
You can use a linear regulator but this will be very inefficient due to the significant amount of current. What is more, a big heat sink is needed to dissipate heat fast which occupies large space. For DC to DC voltage level conversions switching regulators are the most efficient until now.Are there any other solutions? I suppose you could design something using a transformer where a buck converter has its inductor, but that fits in pretty much the same mental "box" for me. How else could you provide such a large amount of current?
It is not a happy situation, but if a resistor is added in series with the regulator the same power will be wasted but the power will go into the resistor instead of the regulator. Leave enough voltage at the input of the regulator for it to regulate ( and consider droop in the 24 v input )You'd be pretty hard-pressed to step down 24v to 12v using a linear regulator; the power dissipation in the regulator would be the same as the dissipation in the load. Not a happy situation.
