Hi folks,
I need some advice from you experts to repair the CC LED driver in my LED lamps. 3 out of 7 lamps don't work any longer, after 8 years of use. The supplier has no spare parts and no other lamps in the same size (needed because the lamps are built into a concrete wall). Due to these circumstances, an option is now to try to repair the LED drivers myself - hopefully with some help from you.
As may be visible from attached pictures, at least the fuse and a capacitor are blown - presumably due to sub-optimal low cost circuit design.
I've added all the information I have in below circuit diagram, drawn from reverse engineering the extracted LED driver. From studying LED drivers in the internet, I had expected to find a couple of resistors (in addition to the VDR), but I don't find and can't measure any.
All LEDs seem to be OK. All 3 LED drivers appear to be failing due to a blown capacitor and fuse (symptoms). The other components look OK, at least there are no sign that they are burned. The black parts under the components on the board are rests from the black foam in which the components were sealed.
Components
F1 Fuse 250V 2A
VDR 7D 471k Smart Lightning Protection Zinc Oxide Varistor blue
IC1 DB107 1A 1000V Bridge rectifier
C1-4 CBB Capacitance 104J, 400V 0.1µF/100nF Feet Distance 10mm
C5 Monolithic Ceramic Chip Capacitor yellow 104, 50V 0.1µF/100nF
C6 Ceramic Capacitor blue 103M 1kV 0.01µF
TR1 Transistor SiHV 9921 0843
D1 MUR 160, 1.0A Super-Fast Rectifier 600V
L1 Inductor
L2 Inductor
My questions are:
1. Is the LED drivers failing due to poor design or age?
2. Will it make sense to exchange all capacitors C1 - C4 (C1 is blown in all 3 LED drivers)?
3. Is a fast or timed fuse the most appropriate?
4. What other components are most likely blown as well and should be exchanged?
5. What is the inductance of L1 and L2?
6. I don't find any documentation on TR1 in the internet. What would be a suitable substitute?
I don't expect all questions to be answered. Any advice is very much appreciated!
Thanks a lot in advance
Red marked components are blown.
Components
F1 Fuse 250V 2A
L1 Inductor
L2 Inductor
My questions are:
