praondevou, is this what you're referring to regarding the diodes and pull up (attached). If not, then yes, if you coudl draw something up this evening, that would be awesome.
In this schematic, I'm not sure I understand what would prevent either Q4 or Q5 from going high and resetting IC4 as opposed to requiring BOTH Q4 and Q5 going high for the reset.
As for the schematic, I'm just using the symbols from Eagle's library...I didn't draw the counters themselves.
I'm not sure what bwack is referring to though
EDIT: I updated the pdf to fix the output of IC5B. Redownload if you downloaded it before this edit.
