Wrong readings of battery level indicator - electrical motorbike
linhvn
Joined Nov 6, 2024
297
I have this battery level indicator but it shows the wrong readings, because after a few days of running the indicator did not reduce any bar, it still showed 4 bars, but all of sudden the electrical motorbike slowed down significantly due to low battery level, but the indicator still showed 4 bars, my electrical motorbike information: 5 acid batteries, each one is 12v, total 60V, battery level indicator is suitable for 60v configuration.
Alec_t
Joined Sep 17, 2013
15,171
Unless you can post (or link to) a schematic of the battery level indicator, diagnosis of the problem will be no more than guess-work.
Even knowing the solution, do you have experience with repairing electronics?
linhvn
Joined Nov 6, 2024
297
this indicator is from china, they tend to hide the datasheet, i cannot find it in the internet.
Alec_t
Joined Sep 17, 2013
15,171
In the absence of a datasheet, can you post a link to the indicator module and/or sharply-focussed pictures of its front and back?
schmitt trigger
Joined Jul 12, 2010
2,296
How to do it...geez, everyone has different ways to write into the calibration registers, and if the vendor didn't provide you with the details, I can't either.
That is the problem of acquiring gadgets without documentation, the norm of low-cost gadgets.
Besides I ignore whether they are only doing a simple voltage reading and via a lookup table performing the bargraph function, or if they are really computing amp-hours, the accurate way.
linhvn
Joined Nov 6, 2024
297
Poor me, now I cannot know the correct battery level, all readings now are just unreliable.
