Would this be a correct way of calculating total resistance?
barrett50
Joined Feb 1, 2016
14
So I have here that
R1 = 470 ohm
R2 = 660 ohm
R3 = 290 ohm
Ry = 500 ohm
Would I be correct in saying that I can join these into 1 Resistor by the follow?
Rs1 = 1/((1/470) + (1/660)) = 274.51 ohm
Rs2 = 1/((1/290) + (1/500)) = 183.54 ohm
then because Rs1 and Rs2 are in a series, I can now do
Rs1 + Rs2 = Rtot
=> Rtot = 274.51 + 183.54 = 458.05 ohm
33,313
Yes, that looks correct except for the sloppiness with your units. It should be, for example
Rs1 = 1/((1/470 Ω) + (1/660 Ω)) = 274.51 Ω
Rs2 = 1/((1/290 Ω) + (1/500 Ω)) = 183.54 Ω
Rs1 + Rs2 = Rtot
=> Rtot = 274.51 Ω + 183.54 Ω = 458.05 Ω
barrett50
Joined Feb 1, 2016
14
Rs1 + Rs2 = Rtot
Thanks for that. I'll be a little more organized next time I post
shteii01
Joined Feb 19, 2010
4,644
When dealing with resistors in parallel, normal people use the formula in this form:
R_{Total}=\frac{R_1*R_2}{R_1+R_2}
It is the same formula like you have, but it is in the form that is easier and more convenient to write and solve.
