with gates do they all wire together?
traymond
Joined Oct 28, 2017
Concerning like for instance
gates, like AND and then NAND gate do these usually have wires joining both AND and NAND gates or do these gates
ALWAYS not ever wire together.
I have seen graphical images of older LS logic gates and it seems these work by themselves and independent from the other
gates.
Im currently intrested in an older CMOS chip layout (very simple) and wondering if the above is always true.
BTW on this forum is it okay to paste in like JPG images and post these or is this forbidden on this forum?
Well the chip Im figuring out is an older CMOS gate level controller (very simple design) Im tinkering with that is. :)
I know this is a silly question but something that I have noticed with older MOS chips, as far as the gates.
I know ONE SINGLE gate has ITS wires but the different gates Im unaware if they INTERCONNECT in the IC circuit?
traymond
bertus
Joined Apr 5, 2008
23,006
You can upload files and images using the "upload a file" button
The popup will show you wich fileformats are allowed
Bertus
Deleted member 115935
Joined Dec 31, 1969
Gates are a great way to learn,
one word of caution, you mention the cmos gates,
they have a few fobels, such as dying at the first sign of static
The old '74' series of LS logic is still around , and come s in nice 14 / 16 pin 0.3 inch wide packages that pne can see, and a lot more resilient to abuse,
WBahn
Joined Mar 31, 2012
33,222
You need to be a lot more specific about what you mean by "wired together".
In general, each node (the common wired connection shared by two or more component connections) need one driver (such as the output of a logic gate) and some maximum number of inputs to logic gates. The maximum number of inputs that an output can drive reliably is called the fanout of the driving gate. There are some exceptions to this rule, particularly with open-collector (open-drain) and three-state outputs, but worry about those when you get to them.
