Wiring of 3 way 6 pin rocker switch to 2 linear actuators
CK12780
Joined Jun 11, 2023
6
is it possible to wire 2 linear actuator to 1 rocker switch and how emergency button can add on it
if possible can show example of wiring diagram
thank you
linear actuator: SUMRET SRA6000
27,362
thank you
NO!! With that amount of information it is not possible!! The very best you might possibly get is guesses.
First you must provide information about the linear actuator connections: are they 2-wire DC powered? or 3-wires, extend and retract, plus a common.
Then we need to have explained if they are both to move at the same time, or independently. Then an explanation of what the switch is supposed to cause to happen.
Then an explanation of an "emergency button" should make happen.
If you are unable or unwilling to provide that information there is no way to provide a correct answer.
