wiring in kenya
driftwuud
Joined Jan 14, 2010
1
Hello all, I am planning a trip to Kenya to completely wire an orphanage. I know that their wiring materials and methods are totally different than north america. If anyone can give me any information about this that would be great.
Thanks in advance.
loosewire
Joined Apr 25, 2008
1,686
On this site there is a post about container power supplies for small
operations,keep the post alive there is information about power all over the
world.
AlexR
Joined Jan 16, 2008
732
Kenya was a British colony and as far as I can gather they use the same power outlets and adhere to the same wiring standards as used in Britain. I don't know if you can find the Kenyan wiring code anywhere on-line but in any case you would not go too far wrong if you stick to the British wiring code.
As Paulo540 stated the supply voltage is 220V-240V so wiring to US wiring standards would certainly not be a good idea.
3ldon
Joined Jan 9, 2010
82
Consider the cost vs benefit vs risk of electrifying a village.
Sure it needs to be to code, but who's code? If you can't afford it, is it better to have electricity and wired up with whatever is available, or none at all?
Code don't differ too much between 120 and 240volts, if you can't find their codes then read up on both the Brittish and American codes, they are pretty much the same.
It's mostly common sense stuff ..don't use conduit as the ground, keep in mind that the earth is dry so use more than one "ground" etc.
