Wiring Echo Button to 3.5mm
Anto26
Joined Aug 24, 2016
5
I need to wire a 3.5mm cord to an echo button so when I acuate the button, it signals the device the button is plugged in to. Does anyone know where I can solder it to?
If I touch the red wire and the ground together it sends a signal, now I just need to figure out how to get that to work inside the button.
Thanks,
Anthony
P. S. I'm trying to make a button for the Xbox adaptive controller.
Ya’akov
Joined Jan 27, 2019
10,240
What you are trying to do is not completely clear. Are you simply trying to use the button as a big switch?
Ya’akov
Joined Jan 27, 2019
10,240
It’s not very well suited to that application. The circular traces you see on the PCB are the contacts for a conductive rubber switch the device uses. The only way to reliably use if would be to include some active electronics. It could be done, but it’s a very roundabout way to get a large switch.
Why not use some other large switch?
Anto26
Joined Aug 24, 2016
5
Right now I just have it going mechanically. I but the ground on the bottom of the switch. And then the red wire on the button part so when I push down they contact and send a signal. That's working fine for me rn.
