Here are micro switches for replacing failed switches in mouses.
Thanks Ya'akov, for the inputSo, it appears that the front motor is used for focus (moving the front element group) and the back motor of zoom (moving the zoom group). Since the is no visible feedback mechanism I assume it used an autofocus system. Since there is no limit sensing, it must have used over-current to detect end of travel.
The best way to adapt this would be to turn the motors into servos of the simplest kind by adding position sensing and some circuitry to allow PWM control—like a hobby servo. This would allow the use of two knobs that would always move the elements to the same position for any particular rotation.
Though relatively simple for someone with a clue, it is certainly more complicated than a pair of switches. But it would seem to be very challenging to achieve sharp focus with a switch like that. I can imagine it being very frustrating shuttling back and forth past focus until you managed it.
Yes Bill. When I tried roughly after fitting everything together, it was working fine. The motors will work fine with 12V 1A supply.I have a few video cameras that have zoom and focus adjustments controlled by momentary switches, rather similar to what I described. there are no problems with getting into focus. A microscope will probably be different, but if the speed is not excessive it should not be a problem. So it might need a PWM drive so as to have enough torque without the speed. A fixed speed PWM drive just for the torque.
I think this looks promising with the micro limit switch setup.As promised:
