wiring a powerswitch?
jarwulf
Joined Jul 7, 2013
60
Hi, I'm trying to connect a battery pack with two wires to a power switch and the switch to two devices. The power switch is single pole single throw. It has two large terminals and two smaller ones which I guess are for the Led inside. The large are labeled 1 and 2. The small 3 and A. How would I wire them up?
35,116
Get out your ohmmeter and test for continuity when the switch is closed
or tell us the model number of the switch and show us a photo.
mcgyvr
Joined Oct 15, 2009
5,394
Here ..
http://www.jameco.com/Jameco/Products/ProdDS/2182397.pdf
looks like you have a SC-WL01A-03BB
datasheet here.. last page has the SC switches..
The smaller terminals are just the ends of a LED.. So as such it requires a resistor inline with the supply to limit the current to 10-20mA.
A switch is typically inserted "inline" on the "hot" lead of any system. So just cut the + wire going from your battery to the devices and put one end of the cut wire to one large terminal and the other cut end to the other side. If you want the LED then you put the + lead of your battery to a resistor..resistor to one terminal for the LEDs and the - lead of your battery to the other terminal.. resistor value must be calculated using the voltage of your battery.
oh and "technically" thats a bad choice of switches as its only UL approved for switching AC..not DC (battery).
shteii01
Joined Feb 19, 2010
4,644
Looks to be EDK SC-WL01A-0xBB.
x is for LED color.
If x is 1, LED is orange, Forward Voltage is 2.2 V, Forward Current 20 mA, needs resistor: R=(Supplied Voltage-2.2 volts)/(20 mA).
x is 2, LED is green, Forward Voltage is 2.1 V, Forward Current 20 mA.
x is 3, LED is red, Forward Voltage is 1.7 V, Forward Current 20 mA.
Maximum Forward Current is 40 mA.
jarwulf
Joined Jul 7, 2013
60
Here ..
Is it any danger to the electronics?
mcgyvr
Joined Oct 15, 2009
5,394
how much current do you intend to switch with it?
Typically if that were to be approved for DC it would only be something like .5A (500ma) max DC.
Like I said "technically" its a no-no to use any device/component in any method that its not "listed" for.
jarwulf
Joined Jul 7, 2013
60
Usually much less but transient spikes somewhat above 2A.
