- Joined Jan 23, 2018
- 28,212
OK, that is a close enough size description. The suggestion for putting an incandescent light bulb in series with mains power is reasonable and 60, 75, or 100 watt bulb will work. I would put that in series with the mains power to terminals #5 and #6, and then use the AC voltage setting on your meter to read the voltages #1 to #2 and #3 to #4 and also the input voltage #5 to #6. That will allow you to calculate the voltage ratio and let us know what sort of transformer it is.
And once again, do you have access to that magnetize/demagnetize machine? Does that machine have a variable transformer? And what is the mains voltage for that machine.?
