Hello everyone,
I'm developing a device that requires two speakers and a microphone wired to a TRRS audio cable. The speakers are directly soldered to the cable and work just fine, however, I am having trouble getting the microphone to work without noise. Below is the circuit diagram for the microphone, it is a Knowles FG-23652-D65. Here is the datasheet. Due to the lack of documentation for recommended circuits and such I was unable to figure out what is wrong and how to fix it. Any help is appreciated!
Some background information:
The TRRS audio jack is connected to a Samsung usb-c to 3.5mm audio adapter. A DC bias voltage for the microphone is provide through the TRRS mic port, which is the same port for the microphone output signal. R1 and C3 make a low pass filter to power the microphone while C2 is a DC block for the audio signal from the microphone output.
