Wiring a 220V Hot Tub
Bigcountry
Joined Jul 4, 2008
76
Can I run the 8 gauge wire from the panel that is located in my garage to my hot tub? It is 100 amp panel in my garage. Someone told me that I have to run it from main meter ( that connects to the electricity to house) and add a GFCI connections before the wire is ran to the hot tub.
I was reading there is numerous codes on Hot tubs and spas.
MaxHeadRoom
Joined Jul 18, 2013
30,708
You also need a manual disconnect within view of the H.T.
Check local codes, Home Depot have the general requirements on their site.
Max.
gramps
Joined Dec 8, 2014
86
In the USA the NEC requires the there be a disconnect for the hot tub within visual sight and at least 5 feet away from the tub. This disconnect can also contain the GFCI breakers.The big box home improvement stores carry such equipment. Depending on the power requirements of your hot tub, 8 gauge wire may be too small. Check the manual. The source should be from your main circuit breaker panel, not from the power meter.
shortbus
Joined Sep 30, 2009
10,049
Lets see, electricity and water and someone that needs to ask unknown people on a internet forum, what could go wrong? Here hold my beer..... :)
mvas
Joined Jun 19, 2017
539
Yes, there are numerous codes on Hot tubs and spas.
Does the National Electric Code and your local codes, allow you to add another Dual Breaker to your existing 100 amp subpanel in the garage?
You need to do some reading & some math to find out.
Do you live in an area that requires an Electrical Permit to be issued, before you can do any wiring?
How did you determine that 8 AWG wire was large enough?
You should draw and post your wiring diagram...
