Wireless serial communication
Loonybin
Joined May 17, 2018
I'm currently working on a little project to make my field tests quicker for myself.
I am trying to design and make a circuit to replace a standard rs232 serial cable with a wireless adapter.
I work as a programmer on fire and security systems and under commissioning, I run back and forth to my computer and equipment.
My plan is to make a wireless connection so I can bring my laptop with me.
So far I'm looking at the hc-12 with a usb to serial ttl chip on to computer end and a hc-12 with a max232 chip on the other end.
Do any of you have any hints on where to go from here, or if there is a better way of solving this?
jpanhalt
Joined Jan 18, 2008
11,087
Welcome to AAC.
I used a pair of XBee modules a few years ago for a similar purpose. I had "one-wire" communication between two PIC's, and the XBee conversion was a drop-in replacement. The coding it uses is proprietary and very quick.
Today, everything has advanced, and I am not recommending XBee specifically. I am recommending looking for a similar drop-in replacement as it avoids having to write coding (e.g., Manchester code) to deal with disturbances in pulse width.
Loonybin
Joined May 17, 2018
Thanks, just found this site and are impressed on it's massive content.
I am trying to make the module as small as possible. The little knowledge I have on Xbee is that you need a mcu like arduino for it to work.
But I might be wrong, I have not used XBee just watched tutorials on it.
I was hoping to eliminate the need of a mcu like arduino. On the HC-12 there is a mcu ready to go, but don't know if it will work for my purpose
AlbertHall
Joined Jun 4, 2014
12,637
I have just bought two HC-12 to experiment with and it seems to be an impressive module and pretty simple to use to make a long range serial link. As far as the hosts are concerned the link is transparent - they can't tell the link isn't via a cable - except for the delay introduced. As long as a short delay isn't a problem for you then I think HC-12 will be a good choice.
