Hello all.
I could use some help locating a wireless relay.
My BMWs lighting has go bad and I'm going to use halogen bulbs and bypass all the fancy stuff running my own harness for lighting.
I will unplug the harness from the headlight switch and use that. What I want to do is have a board inside the car that receives inputs that will switch a corresponding boards relay contact that's on the outside of the car. I need 3 separate inputs inside the car that will switch 3 separate outputs outside the car. For Park lights, Headlights On, and Auto.
So that I don't have to drill holes.
Something like these but not so expensive: https://www.controlanything.com/Relay/Relay/WIRELESS_MIRC
Thanks guys.
Thanks guys.
