Thanks for your interest, well I'm not a electrical engineer by any means, so by better I was hoping to see if the circuit I'm using is the one to use.if it's ok,not sure if I'm using the correct resistors,transistors etc.How do you define better? Have you made measurements and identified any losses?
One thing you might consider is the air gap between rotor and stator. The smaller the better but of course you need mechanical precision to avoid contact.
Is there pictures there for you to look at?It's not that hard to work out mate, Motor!!You see, in the first post you ask how to make this more powerful. I have a hard time decoding what THIS might actually be, how it is supposed to operate and what should it actually do. You need to do a lot more explaining if you want some help.
Sure,I'll do my best. So I'm using the H-bridge controlled by the hall sensor to change polarity on the stator electromagnet to oppose the rotor for motion. The bottom part of the circuit is switching to give Ac for the wireless transmission to work then rectified to feed power to the rotor electromagnet. Goal is to get it to work correctly. As its gone from a simple idea in my head to a working model that I can't find anywhere else. So would love to make a decent prototype if we can sort it out.Current limiting?
But anyway, a circuit description and a statement of the goals would be nice before we can make it "better".
Yes, exactly. Is this the way to go or is there a better circuit available? If this ones ok! Can I make it more powerful to make my electromagnet stronger?I don't understand why you're using 12v dc to make an hf oscillator pulsing a pushpull transformer, then converting the Ac back to Dc to feed a coil?
Is the transformer a wireless connection pickup, like a wireless charger?
Well Dave I thought like a conventional induction motorStill dont get why you want a Wireless motor,?
surely when you connect power to it its going to move from its position and what psu is feeding the stator a battery or a dc psu?
im using wireless for the rotor so there's no brushes,friction,magnets like a coventional motor. I'm using a battery atm for the whole thing. What do you think I should use.Still dont get why you want a Wireless motor,?
Ok, trying to learn here, but isn't that how a Ac induction motor works? Wireless powered to induct the rotor?You're better off designing an ac motor, with a rotating field, like a three phase motor, wireless power is too wasteful, stick to conventional brushes.
Funny you say that max, that's where all this started for me. That actual Fisher-Paykel motor. Thought I could improve on that by eleminating the magnets with more powerful electromagnets with no brushes. Have defentaly appreciated the input from all you guys here. But still. If you think of something I can try to improve this motor or the circuit I have would be great. ThanksYou may be better off to make a BLDC motor, these are gradually replacing both induction and DC brushed motors, an interesting concept is the outrunner, such as used in RC and the Fisher-Paykel washine machine motor.
http://www.directdrivemotors.com/
