Wireless power tranfer 24v - 30 watt
fernandoc83
Joined Jul 29, 2019
8
Anyone know how to do wireless power transfer at 24 volts and be able to slow stop and speed up a motor at 30 watt max?
maybe modify one of these:
Thanks
fernandoc83
Joined Jul 29, 2019
8
there is a couple different ones online wondering if i can modify one?
  • Input Voltage Transmitter: 12VDC
  • Output Voltage Receiver: 5VDC (regulated)
  • Output Current Receiver: 400-500mA
  • Distance between Transmitter and Receiver: 1-10mm
  • Dimesions: 21x9x2.2mm (Tranmitter), 27x5x2mm (Receiver)
  • Coil Dimensions: Radius 30mm, Height 0.85mm
  • Coil Inductance: 10µH
  • Coil Isolated: yes
djsfantasi
Joined Apr 11, 2010
9,237
Without another source of power, my answer is that you can’t with these modules.
First, you need 24V; these only transmit 5V of power. Just using that for an estimate, the efficiency is around 40%. Thus, to get 24V out, you’ll need 57V input.
Secondly, you want 30W. These modules only provide 2.5W of power. You’re more than 10x off.
You’ll be a lot better off starting from scratch.
BobTPH
Joined Jun 5, 2013
11,609
You could use 15 of them in 5S3P to get 25V at 37.5 W, followed by a buck converter.
Why do you want wireless?
Bob
fernandoc83
Joined Jul 29, 2019
8
Yeah wouldn't mind starting from scratch just not sure what I really need!
thanks
djsfantasi
Joined Apr 11, 2010
9,237
Just for a reality check, let’s do some rough calculations. The blue LED needs <20mA and drops about 3.5V
The video uses a 9VDC battery to get that 3.5V. Again, about 40% efficient (calculated by dividing 3.5 by 9). To get 24V, you’d have to input 60VDC!
There is no resistor value or transistor that will get you 24V and that high a wattage with this circuit.
I won’t go in to the current calculations, because I think the previous results are instructional.
I also have doubts as to whether the device in the video is real. Some reality check calculations are the source of my suspicions. But I must be wrong, because everything on the Internet is true!
Alec_t
Joined Sep 17, 2013
15,149
Note that the quoted transferred voltage/curent values are for the condition where the two coils are only a few mm apart. The energy transfer drops off rapidly with coil separation.
djsfantasi
Joined Apr 11, 2010
9,237
Ok, I get it... I was incorrect in my presentation, but not in my point!
How does that information apply in this project? Given that an estimate of output power is 0.07W, in the example circuit, with an input of 9V @3.3A (if that’s real) and a power of 29.7W, what’s the real efficiency! (Not the projected efficiency for illustrative purposes)
Using your input and recalculating my example, I get an efficiency of 0.24%. So to get 30W out, I get that you need 124W input. So tell me, what combinations of voltage and current do you need to get 124W?
So, you have two variables and one result.
If your input voltage is 5V, then you need to supply about 25A. That’s a lot...
If your input voltage is 12V, then you need to supply more than 10A. Still a lot!
If you were to supply 120V, you’d need to supply an Amp of current.
Or looking at it the other way, if you supplied 500mA of current, you’d need to supply 248v of input voltage?
Does everyone see a problem here?
A better solution is to transfer a smaller amount of current and voltage, much less than 30W. Then, use the lower voltage and input to a driver at the higher power level.
Simply, it is impractical to attempt to directly wirelessly transfer 24VDC at 30W. Instead, transfer a signal that drives the higher power requirement.
