WIRELESS COMMUNICATION
amaljames
Joined Jul 8, 2019
3
HI all
I have a project which contains 5 stm32 controllers which are connected to each other in rs 485 line, the data sending to all stm32 devices is the same. Actually, I want to replace the 485 wired communication to wireless communication mode please suggest any wireless module which can replace the rs 485 line completely wireless. I searched the internet but I didn't get an exact idea about it please help. The attachment consist of a block diagram of my system please have a look at it.
camerart
Joined Feb 25, 2013
3,847
HI all
Hi A,
Have a look at HC-12 radio modules, they can work with HSEROUT/IN
Cheers, Camerart.
Picbuster
Joined Dec 2, 2013
1,062
HI all
are you using rs485 1/2 or full duplex four or two wire?
Point to multi point?
master=>slave
or point to (multi point) each node is able to start conversation with any node?
What is the turnaround time excepted by the host ( overdue ==> generate communication error)
Picbuster
amaljames
Joined Jul 8, 2019
3
master=>slave
Picbuster
Hi thanks..
How many receivers can connect with this HC-12 transmitter module??
I want to communicate with 5 to 6 receivers is that possible??
amaljames
Joined Jul 8, 2019
3
master=>slave
Picbuster
Hi thanks...
1, half duplex.
2, 2wire T+ and T-.
3, No master to slave, single point and multi point communication (transmit and receive process).
4, All multi points nodes will acknowledge to single point node after successful transmission.
5, No communication between multi point nodes.
6, No worries about turn around time.
Picbuster
Joined Dec 2, 2013
1,062
Hi thanks...
1, half duplex.
2, 2wire T+ and T-.
Turnaround time is unavoidable when using 1/2 duplex.
RS485 input is listing to the transmitter when the line is free it will send an answer.
Implication:
Time needed to evaluate incoming data.
Time needed to switch from receive to transmit in radio-set and electronics.
The line is not busy during that time allowing any node to start conversation and collision is possible.
Picbuster
