Hi folks,
Joined the forum to ask some advice on a project I'm working on.
I have fitted bi-xenon projectors in my car that used to use a two bulb set up for the high/low beams. The low main beam halogen bulb has been replaced by an HID bulb and comes on with the usual switch and the high beam bulb has been removed and replaced with the bi-xenon shield solenoid. My high beam works great but only when the low beam is on - meaning I can't flash my lights during the day when the low beam is off (the solenoid still functions but there is no light from the HID as this is now the only bulb and only functions with the low beam switch).
On cars that are factory fitted with bi-xenons, when they flash their high beam during the day or with their lights off, the HID ignites to flash and the solenoid activates the shield.
I have connected the positive end of the solenoid to the low beam circuit (Fig 1.0) so when I flash the the high beams the hid bulb ignites and the solenoid activates. However when I turn the low beams on, the solenoid activates essentially turning it into another high beam switch. I have played around with the idea of putting a diode in as seen in Fig 2.0. Would this work?
While writing this post out I came up with the idea of connecting the circuit after the solenoid as seen in Fig 3. Would this achieve what I'm after or would the flow simply bypass the HID bulb and take the path of least resistance? Please tell me I've not stumbled across a completely obvious and extremely easy solution that's been staring me in the face all along?
Many thanks for taking the time to read my post and special thanks to those that take the time to help me on this!
Kind regards,
David
Kind regards,
David
