Wine cooler problem to find parts
Status
Not open for further replies.
pierro105
Joined Aug 21, 2017
Hi everyone,
I have my wine cooler but as soon as I put a new fuse, it blows immediately.
I found 2 parts burned but for one i'm not able to know what is it.
Can you help me ?
Thank you !
Pierre-Olivier
AlbertHall
Joined Jun 4, 2014
12,652
It looks like a VDR and if it is near the mains input to the board then that would confirm it. It is there to protect the board from spikes/surges on the input voltage. You need one rated for your mains supply voltage.
AnalogKid
Joined Aug 1, 2013
12,265
You don't indicate where the bad parts are on the board. The photo is of a small ceramic disk capacitor, but where it was on the board is important.
That is a switching power supply. The fuse blowing immediately indicates that the problem probably is on the primary side, maybe a shorted bulk filter capacitor or switching transistor.
Are there any components on the bottom side?
ak
pierro105
Joined Aug 21, 2017
Woww thank you for the fast answering !!
The part is in serial with the line.
How can I know the value of the component ?
AlbertHall
Joined Jun 4, 2014
12,652
If the green thing is in series with the line input then it will be an NTC inrush current limiter (though it is labelled RTC which isn't an abbreviation I've come across.
Status
