I'm doing my research and I'm hitting a wall in cant get past
I cant edit title for some reason wind and water lol. I have a water stream
Mod: Edited Title.E
I'm trying to supply my workshop in the woods with electric . My current wind turbine isn't upto power I need to go bigger
My workshop is powering 1500watts constantly 24/7 for my kiln room security computer and cold meat room.
I've been researching and hopefully for notes and help.
1 or 3 phase power ? Old mills use 3phase and they look efficient but what's the catch as I saw someone say dont use 3phase cant remember why. But then I've seen them saying dc all the way others sware by ac...
Confusing..
So high volts at low rpm ..
Ac or dc do I need a converter or does my inverter handle that still...
Talking of which what is the wattage on an inverter doing like do I need to match it up to the task or just max out. 300w or 2000w is it the charge rate at what it can handle arrghhh??
Car alternators.. 50a ay 12v bit rpms high 1000idle and 10k max.. so does it never reach 50a? Or is 50a delivered slowly.. hm so many guides counter what they teach so here I am again.
Some say use car alternators there amazing others day they wont deliver due to low rpm of the wind or water..
Treadmil.. now I got 2 motors. These range 50v to 280v 500rpm to 5krpm
234w 130v at 500rpm 1.8amp
1500watt 220v at 4600rpm 8amp
Amp x volt =watts or power
So what is a watt on a generator like I'd thaught tovlook for higher wattage not v x a x rpm
So the aim is 0.035volt min
And rule 5amp minimum.
To generate enough power..
Volt ÷rpm =power out.
220÷4600=0.047 and x500rpm (speed I get) 23.5volt x 0.8 efficiency 18.8volt
At 500rpm I get 18.8 volts
Power is v x a so 18.8x5amp = 150w?
Now why is there 2 volt... 220v then I do maths to work out 18.8 volt ?
What is it that charges the batterys or runs the power direct off the inverter ?
I mean if I need 1500watts surely the treadmil is only producing 150watts if I am reading right ??
So I need to get more voltage at 500rpm?
I can run 2 water wheels 2 motors
But stil that's 300watt?
I cant get my head around what is what
How dovi know how fast the voltage is delivered to the batterys ? Or meaning how do I know howmuch immidieate power I am getting
How can I achieve this what motor do I need really cause my headaches hurting 19 hrs up this time over 5 weeks and I'm following people who are recommending ametek low 500rpm high 99v but I cant see damn why that out powers my motor mine looks better lol
2am madness I cant sleep I see volts and I cant workout where the hell they are
Please be nice lol I know I'm mad... but so was einstein and that's why were here lol
Have a good day
Mod: Edited Title.E
Confusing..
Have a good day
