Wilson current mirror problem
OggiSerbia
Joined Dec 28, 2017
34
I have an easy Wilson current mirror problem to solve. I tried to do it but I am not sure if it is correct.
Here is the circuit:
The problem is to find (Ir/I), i.e. Currence Ir over currence I. It is assumed that all the transistors are equal: beta (currence amplification) is the same.
Here is my solution:
Image No.1:
Image No.2:
Image No.3:
danadak
Joined Mar 10, 2018
4,057
Q3, Q4 scaling the output current by 2 ? Assuming they are interdigitated match
pair geometry. Or splitting current to reduce T effects ?
Or eliminating CM effects of source I source ? Or eliminating output supply
effect on output current due to finite output sink. To raise effective complience
of mirror and increase finite dynamic R of output transistor ? The analysis
should lead to answer.
Guess on my part.
Regards, Dana.
MrAl
Joined Jun 17, 2014
13,793
Image No.1:
Image No.2:
Image No.3:
Hello there,
I used a different approach by substituting an equivalent topology so i could write the equations more directly and got the same result. So you must have done something right :)
