Will 3x the amp rating damage it?
1quickquestion1
Joined Oct 13, 2017
22
I'm building an electric skateboard and the speed controller is supposed to be connected with a 25v 2000mah battery. If I connect my 25v 6450mah battery too it will it damage the speed controller or the motor? I know voltage is really what I should worry about, but something feels off about the wattage going up by so much.
Papabravo
Joined Feb 24, 2006
22,082
No. Check the units. "mah" stands for milliampere hours, and it is a measure of battery capacity. Battery capacity has nothing whatever to do with watts. Watts are determined exclusively by the load. For example, your 2000 mah battery can supply 2000 mA for 1 hour, or 200 mA for 10 hours, or 20 mA for 100 hours. What you don't know is the voltage after those discharge periods. They may or may not be the same. Some batteries object to being rapidly discharged, others don't. Get the picture?
dendad
Joined Feb 20, 2016
4,637
You can think of it like putting a 3 times larger fuel tank on the skateboard. As long as the voltage is the same and the new battery is designed to supply the current required by the motor, you can now go 3 times longer.
