Switch Rating for Series Cells
johnyradio
Joined Oct 26, 2012
615
If i place a switch between two cells, should the switch be rated for the voltage of one cell or both cells? I'm guessing just one cell (4v in this example):
28,279
In all applications the minimum voltage rating of the switch should be at least the open condition voltage across the switch. What other purpose does the voltage rating serve???
28,279
I think you can choose a switch rated for 8–12 V DC.
Once again, elementary DC circuit analysis reveals the validity of my prior statement: " In all applications the minimum voltage rating of the switch should be at least the open condition voltage across the switch."
Why would one consider any other possibility?? A voltage always is considered as defined between two points . And that is how it would be measured.
