Wien Bridge Oscillator Problem
Volt
Joined Nov 28, 2008
24
Hi, I need to design a wien bridge oscillator with a frequency of 20kHz, the values for the resistors and capacitors in the tuned network i've calculated are 500 ohms, and 16nF. However when I simulate this the frequency of the oscillations is 16kHz.
I don't know why this is, can anyone explain this and help get the right frequency.
thanks
:eek:
Wendy
Joined Mar 24, 2008
23,864
Have you taken the input impedance of the amplifier into account?
Seriously, we need a schematic, there is no way we can even begin to help due to lack of information.
Volt
Joined Nov 28, 2008
24
I'm simulating with an ideal op amp so I suppose the impedance isn't an issue.
I have attached the schematic, on the frequency selective components:
R1=R2= 500Ω
C1=C2=16nF
I work that out to be:
1/((2pi)(500Ω)(16nF) ≈ 20 kHz
but it is only simulating to 16kHz.
The other component values:
R3=18.2 kΩ
R4= 10 kΩ
R5= 5kΩ
Thanks
kingdano
Joined Apr 14, 2010
377
cool app note
i see a useful circuit i can build at work
an encoder simulator - quadrature oscillator into a schmitt trigger or other sine to square wave converter.
then i can use that signal to drive fet gates to switch on 12V or 24V to the inputs of our printers.
i think they need 24V...will check tomorrow.
might help me prove my knowledge of analog...thank you app notes.
