why would a calculator have an RF antenna?
Vignelli
Joined Nov 13, 2023
20
I was replacing the battery in a calculator.
wait a minute, it's got an antenna circuit in it?
diode, capacitor, "RF"
why would a calculator have an antenna circuit?
anybody got an explanation?
Ya’akov
Joined Jan 27, 2019
10,263
Welcome to AAC.
It‘s not an antenna. The diode is power related. The split circular pad is the type designed to be used as jumper with a solder bridge, The RF doesn‘t mean radio frequency.
Is there something on the back of the case that uses the two square pads as contacts, like a piezo buzzer, or the battery holder?
Vignelli
Joined Nov 13, 2023
20
no, nothing inside or outside the back of the case. featureless plastic slab. screw it on, that's it.
what else might RF stand for?
Ya’akov
Joined Jan 27, 2019
10,263
I’m not sure. I do know that’s not radio frequency related, though. I think it is an alternative mounting pointing for a different or additional diode.
WBahn
Joined Mar 31, 2012
32,997
It's very possible that the same board is used in different calculators and the distinction is made by whether or not that spot is populated.
The first thing that comes to mind when I see RF on a circuit board is a reference designator for something like a feedback resistor. I don't know if that makes sense for that circuit or not.
Alec_t
Joined Sep 17, 2013
15,132
Considering there's a pcb hole there, most likely for heat dissipation, my money says it's a Resettable Fuse.
But I'm surprised a calculator would need one, except perhaps for reversed supply protection?
Edit:
And why a spark-gap across the diode?
strantor
Joined Oct 3, 2010
6,875
Could be that solar powered calculator needs reverse polarity protection in case the light shines backwards. But since this is a cold war era calculator, my money says this calculator had (or didn't have) a remote listening device in it, depending on where you bought it. This one must be from Iceland or something as the RF component has been deemed not worth installing.
/s
Externet
Joined Nov 29, 2005
2,645
The diode nests in a pcb hole to give clearance to the lid and prevent breakage as other components are less thick.
The spark gap is not; it is solder pads to short-circuit the anode and cathode traces with or without the diode in place. The square pads 'RF' is a provision for an additional component to enable a feature/function or for a test probe pair aligned to them fitting in the pcb hole during manufacture.
27,802
If the PCB is used for a number of markets, RF might be for "Required Fuse", because some parts of the world are vastly paranoid about fault currents.
Or it may be an abbreviation for words in a non-USA language. And looking at the rest of the picture, it may also mean "remove function."
sparky 1
Joined Nov 3, 2018
1,218
a pcb designer may have been told because a charger might be used and there might be a product safety compliance so they left an open pad and room for a very small fuse. the nomenclature used for a pcb part name abbreviated RF Ribbon Fuse. Unlike the schematic symbol for fuse the engineer could measure the cut out to determine the correct size solder in mini fuse given the board height clearance. The calculator company would understand ribbon fuse and hand cranks.
The acceptance of chip on board and history is interesting but less logical today, the link below you can see that traditional calculators drew current but consumers may have wanted to run there new calculator on a walwart because of the conceived battery life issue from the past.
In order to ease consumers into buying more batteries Radio shack introduced a battery card you needed a full row of punched stars to get free battery.
The Calculator-on-a-Chip (vintagecalculators.com)
Externet
Joined Nov 29, 2005
2,645
Never seen a solar powered calculator in need of a fuse.
The square pads in question connect only to the chip on board. Perhaps tells the chip to use the decimal comma or decimal period or things like that for different world markets.
Knowing the chip part number should clear the doubt at its data sheet. Those other etched numbers could tell something if relate what processor chip is meant to be installed in that pcb.
