why the output of this flip flop is just spikes??
Hayder
Joined Mar 6, 2016
32
Hello:
I was playing with some flip flop circuit, then instead of Qbar I connect Q to input of last stage , so I got spikes !!
is just spikes !!
Hayder
Joined Mar 6, 2016
32
I;m sorry. I don't understand , I just plot this circuit, if I change the output from Q into Qbar the output is like this
dl324
Joined Mar 30, 2015
18,248
You need to provide us with more information.
What is the logic family? What are nodes n1 and n2? What is the supply voltage?
Not many logic families will toggle at GHz frequencies.
If we assume that the flip flops initialize with Q=0, what will the flip flops do with logic 0 on the inputs?
You should probably stop using simulators until you have a better understanding of fundamentals.
Hayder
Joined Mar 6, 2016
32
I thought its just a simple and not need much explanation
- V is 1.5v
- its toggle in seconds case.
- its not logic IC, its logic build from cmos
please if you have document about these logic and freq dividers I'm appreciate
AnalogKid
Joined Aug 1, 2013
12,077
If you built the flipflops out of logic gates as you said, then we *really* need to see the schematic.
Why do you think the output you have is wrong? What output did you expect to see?
ak
dl324
Joined Mar 30, 2015
18,248
In the first case, you're basically feeding Q to the D input. What do you expect a D FF to do in that case? Not knowing what n001 and n002 are, I can't even guess what the spikes are from.
Since you're designing the flip flops from MOSFETs, we need to see the schematic.
AnalogKid
Joined Aug 1, 2013
12,077
I know what the spikes are from, but it is too difficult to discuss without the actual circuit schematic.
ak
