why My ups mosfet sparks on battery mode?
rahulb
Joined Jun 5, 2019
44
Hi Everyone,
My UPS 600 VA with battery 12V 7 AH uses mosfets P55nf06. It works normally on mains voltage but when it switches from mains to battery power, a sparks is generated on heatsink to which two of the mosfets are added.
I changed the mosfets but the problem remains the same. On spark, the ups switches off for few seconds.
what could be the reason?
thanks
Dodgydave
Joined Jun 22, 2012
11,395
The mosfets should be isolated from the heatsink with mica washers and mouting kit screws.
Check the Tab doesn't make Continuity with the Heatsink.
