Why my relays are overheating
Ahmet Pehlivan
Joined Oct 16, 2022
28
Hi everyone, when i power up the circuits even i don't trigger the relays, they are overheating. When i try to trigger them sometimes they are not closing if they closed once i can't open them without power off the circuit. What can be the problem ?
ronsimpson
Joined Oct 7, 2019
4,853
To make heat there must be voltage and current at the same time. If there is no voltage on the input, then there must be current in the output. Is there a load?
Does the relay say 5 VDC?
KeithWalker
Joined Jul 10, 2017
3,625
If there is no voltage on the input, then the output must be causing the problem. Do you have the power and load connected correctly. I suspect that you have the polarity reversed.
28,502
We are shown a block with terminals and at that point no other information. So there is no reasonable way to expect a useful answer. then much later we are told a part number. and NEVER actually told the actual operating conditions.
and then, for the origin of the circuit " When i look for examples, i saw something like this so i used it. "
I suggest that it was not a reliable source at all.
Without adequate information the best one can hope for is random guesses!
For a "relay overheating" problem the voltage must be stated, as well as the current, both to operate the relay and to define the contact current.
