Why LED is not turning OFF - 8051 Timers
Djsarakar
Joined Jul 26, 2020
489
In Timer 0 Mode 0, TH0 work as 8 bit timer and TL0 work as 5 bit Timer. TH0 counts up to 31 and then reset to 00 and increments TH0 by 1
Suppose we load 0 in the timer then the timer will overflow in 2^13 i.e. 8192
1msec / 34.7222 uSec/count = 28.8 counts
256 - 28.8 = 227.2
I am only confused, what should be loaded in TH0 and what should be loaded in TL0?
TL0 = 0x1F
TH0 =0xE3
Djsarakar
Joined Jul 26, 2020
489
I my trying to toggle LED at every 40ms (40000)
1 tick takes 1.085us time
40000 ticks take 43,400 us
Program suppose to toggle LED at 40 ms
C:
#include<reg51.h>
#define FlagSET  1;
sbit LED =  P2^0;
void main (void)
    long int counterFlag = 0;
    TMOD = 0x00;  //Operation mode0, 8 bit timer/counter(TH0) with No prescale
  TH0 = 0x01;
  TCON = 0x20;   // Enable Timer0 overflow flag TF0 //
    while(1)
    if (TF0 == 1)
            TF0 == 0;
            counterFlag++;
            if (counterFlag == 43400)
                  LED=~LED;               // Toggle LED //
                      counterFlag = 0;
I don't know how many ms of delay I am getting but LED toggles at some intervals
jjw
Joined Dec 24, 2013
823
C:
#include<reg51.h>
#define FlagSET  1;
sbit LED =  P2^0;
void main (void)
  TH0 = 0x01;
    while(1)
    if (TF0 == 1)
            TF0 == 0;
            counterFlag++;
                      counterFlag = 0;
TF0 == 0; should be TF0 = 0;
JohnInTX
Joined Jun 26, 2012
4,787
256 - 28.8 = 227.2
TL0 = 0x1F
TH0 =0xE3
Per #11: 34.7222uSec/count comes from 11.0592MHz / 12 /32
You already have allowed for the 5 bit prescaler so you just load the result of 256-(time / 34.772uS/count) 227 in your example into TH0 and treat it as an 8 bit timer with 5 bit prescaler running at 34.722 uSec/count.
To use the full 13 bits you use the input frequency of 11.0592MHz / 12 = 921600Hz and the familiar 1.085 uSec/count. The calculation is 8192-(time / 1.085uS/count). The lower 5 bits of the 13bit result go into TL0 and the upper 8 bits to TH0.
For 1mSec:
8192counts - (1ms / 1.085uS/count) = 8292 - 922 counts = 7270.
7270 = 1110001100110 binary. Split into 8 and 5 bits:
11100011 00110
TH0 = 11100011 = E3h
TL0 = 00000110 = 06h
Either way, the max time using Mode 0 is 2^13 * 1.085uS ~= 8.88ms
Why not use Mode 1 which has a complete 16 bits without all the goofy 8:5 bit split OR use Mode 0 and just let TL0 run as a 5 bit prescaler with 8 bit calculations for TH0?
The code in #23 uses Mode 0 and TL0 as a 5 bit prescaler. With that, what should you set TH0 to for your 1ms time?
EDIT: Thinking about this, just use Mode 0, leave TL0 as a free running prescaler and just load TH0 with the calculated count: TH0= 256-(time / 34.772uS/count).
Djsarakar
Joined Jul 26, 2020
489
code in #23, LED should be toggle at every 40 ms.
Timer 0 gives maximum time 8.8 ms in mode 0
Timer overflow at every one ms so when counter flag is equal to 40, LED will toggle
C:
#include<reg51.h>
sbit LED =  P2^0;
void main (void)
  int CounterFlag =0;
  TH0 = 0xE3;            /* Load 8-bit in TH0 */
  TL0 = 0x06;            /* Load 5-bit in TL0 */
  TR0 = 1;                /* Start timer0 */
  TF0 = 1;              // Enable Timer0 overflow flag TF0 //
    while(1)
       if (TF0 == 1)
           TF0 = 0;
           CounterFlag++;
          if (CounterFlag == 40 )
                  CounterFlag = 0;
Timer overflow for 8.8ms so when counter flag is equal to 40, LED will toggle
C:
#include<reg51.h>
sbit LED =  P2^0;
void main (void)
  int CounterFlag = 0;
  TH0 = 0x00;            /* Load 8-bit in TH0  */
  TL0 = 0x01;            /* Load 5-bit in TL0 */
    while(1)
       if (TF0 == 1)
          TF0 = 0;
           CounterFlag++;
                   if (CounterFlag == 5 )
                               CounterFlag = 0;
I am writing code for 40ms delay time in timer mode 1
Djsarakar
Joined Jul 26, 2020
489
Timer mode 1 for near 40ms delay
65536 - 37000 = 40145
40145 = 10011100 11011011 = 9C DB
C:
#include<reg51.h>
sbit LED =  P2^0;
void main (void)
  TMOD = 0x01;  //Operation mode 1,
  TH0 = 0x9C;
  TL0 = 0xDB;
    while(1)
       if (TF0 == 1)
            TF0 = 0;
            LED=~LED;
Djsarakar
Joined Jul 26, 2020
489
I don't think so.
Delay for 1ms mode 0
256 - 28.8 = 227.2
11100011
C:
#include<reg51.h>
sbit LED =  P2^0;
void main (void)
  int CounterFlag =0;
  TH0 = 0xDB;            /* Load 8-bit in TH0 */
  TL0 = 0x00;            /* Load 5-bit in TL0 */
    while(1)
       if (TF0 == 1)
           TF0 = 0;
           CounterFlag++;
                  CounterFlag = 0;
JohnInTX
Joined Jun 26, 2012
4,787
0b11100011 =0xE3
Correct so why are you loading TH0 with 0xDB? for 1msec in Mode 0?
You are mixing the math between the 8bits with a 5 bit prescaler and 13bits. You can't do that. Your calculation above the code indicates 8bits in TH0 with TL0 running as a prescaler.
Pick ONE mode and stick with it until you have the LED flashing at the rate you have defined. As before, I recommend using the timer ONLY as Mode 0, 8 bits with a 5 bit prescaler i.e. 34.722 uSec/count in TH0. Ignore TL0 and let it free run.
Djsarakar
Joined Jul 26, 2020
489
Timer0, Mode 0, 8 bits with a 5 bit prescaler
Toggle LED at 40ms (approx)
Timer overflow at every 1006.938 uSec
C:
#include<reg51.h>
sbit LED =  P2^0;  /* LED connected to Port P2.0 */
void main (void)  /* Program start */
  int CounterFlag =0;
  TH0 = 29;            /* Load 8-bit in TH0 */
  TL0 = 00;            /* Load 5-bit in TL0 */
  TF0 = 1;             /* Enable Timer0 overflow flag TF0 */
    while(1)
       if (TF0 == 1)   /* check Timer0 overflow flag */
           TF0 = 0;    /* clear Timer0 overflow flag */
           CounterFlag++;  /*increment count */
          if (CounterFlag == 29 )
                  LED=~LED;               /* Toggle LED */
                  CounterFlag = 0; /* clear counter glag */
35,326
Imagine that you were building a clock and you do not have any fancy equipment to measure time.
How can you determine that the clock was advancing once every second within some reasonable estimate of accuracy?
