Why is my DPDT Switch not working?
Alice24
Joined Apr 22, 2011
46
So I have a DPDT Switch that I want to connect to a motor in order to be able to switch its polarity and turn it off.
The model of the switch is MCR13-28E-01 and I'm using a 3V battery energy source. I've done exactly as instructed in all the DPDT online guides (images attached of everything I've just described)
But, it doesn't work. If I connect it without the toggle switch, it works (it rotates slowly, but it does work).
What can it be? The DPDT switch is brand new.... and I know it works because when I try to connect it as just a switch (not in order to reverse polarity) it works as a regular switch
bertus
Joined Apr 5, 2008
22,922
Do you have the details on the used motor?
As far as I can see there is a gear box on top of it.
What is the gear ratio of the used gear box?
Bertus
djsfantasi
Joined Apr 11, 2010
9,237
And also, the diagram labeled "DC motor rever..." shows just 4 wires connected externally to the switch, excluding the 2 crossover wires. However your picture shows 6 such wires. Where are the extra pair connected?
Normally, 2 wires are connected to the power source and 2 more wires are connected to the motor. Like the diagram you attached.
Can you explain where you have your wires connected and why there are a pair of wires that do not correspond to the diagram you posted?
Alice24
Joined Apr 22, 2011
46
@djsfantasi - I wrote my reply before I saw your post. I'll reply to your post soon.
@ bertus - First off let me say thanks for keeping up with me, why it ain't working is driving me crazy.
Speed doesn't matter to me one bit; I just want to make sure my DPDT switch works, and as I've said if I connect it just to the battery it does work, it rotates very very very slowly but nevertheless it rotates.
Anyway, I tried to do the same with a much tinier motor (I think it's a stepper motor since it rotates only in certain degrees) that works on a much lower voltage and it also didn't work... I don't have the model for the smaller motor I've tried it with but I do have a picture attached, it's a motor that came with the arduino starter kit. On 3V without the switch it runs crazy fast. I'm also unable to get it to reverse its polarity but if I play around with the connections I'm able to turn it off and on with the switch.
Alice24
Joined Apr 22, 2011
46
Yes, consider them not connected anywhere. At first those extra wires weren't there; it was "exactly" like in the drawing, but after numerous attempts I got desperate and soldered those wires to try to troubleshoot the issue and try different connections.
djsfantasi
Joined Apr 11, 2010
9,237
Stepper motors don't work the same way. It won't work in your scenario. You need a completely different driver circuit. Google "stepper motors"
In order to get your DPDT switch to work and reverse your motor, we need some extra info. That is, please answer my questions in my last post.
Alice24
Joined Apr 22, 2011
46
@Max & Bert - OK, my bad for trying to use stepper motor as comparison.
@djs - OK, considered them cut. Now it's exactly like the drawing.
As to your question (I believe it's just one that I didn't answer), here is my wiring diagram that I just did (if I were to take a picture, it would look too messy).
bertus
Joined Apr 5, 2008
22,922
The way it is on the breadboard, it would short the battery and the motor will not work at all.
In your openings post you used the following wiring diagram:
Bertus
Alice24
Joined Apr 22, 2011
46
It's been a little while since my electronic college days :) even then it was all chalkboard and nothing practical so I'm struggling in converting diagram to real life. Could you please show me how the connection would look like on a breadboard?
bertus
Joined Apr 5, 2008
22,922
I downloaded Fritzing and made the following drawing for you:
I could not find the motor symbol, so I used the white symbol for the motor.
Bertus
Alice24
Joined Apr 22, 2011
46
First off-- thanks for downloading Fritzing for me :) hope it would serve you for more than just me^^
However, that's exactly what I did except I didn't show that I crossed the wires since I figured that was a given... my bad assuming it would a given. Here, let me just show you a picture of my connections so we're on the same page; it's not as messy as I thought. I'll also redo my Fritzing accordingly and add a picture of my toggle switch backside again.
Alice24
Joined Apr 22, 2011
46
Oh wait a second, I forgot one wiring that I have that you don't... the middle section of the switch. Is that my problem? I shouldn't have soldered the middle section together? I have no idea why did I do that. That must be what's causing the short circuit
Alice24
Joined Apr 22, 2011
46
Yep, I'm an idiot! Must've did the middle solder because of looking at multiple resources or just a brainfart, who knows. Thank you very much for showing me the way, I got it to work. :)
If there was a way I could give you karma or 5 stars ratings, you'd be getting it all right now! Much much appreciated!
