Why IR receiver is black?
swato
Joined Nov 30, 2021
YG1006.png this is a YG1006 NPN Photo transistor. Popularly known as IR Receiver.
I have a question , why the top is black? I know a perfect black is a good reflector ,but what it does matter for infrared receiver?
DC_Kid
Joined Feb 25, 2008
1,242
Probably less about color and more about the plastic characteristics for being bandpass filter for IR.
Side tidbit (good to know) - if you are doing UV-B work, std glass and plastics will block UV-B.
35,112
Side tip:
Older digital cameras respond to IR light.
Simply view a working IR LED on the camera's screen.
Newer smart phones are less sensitive to IR.
Ya’akov
Joined Jan 27, 2019
10,294
Black absorbs all wavelengths of light so no light would reflect from or pass though the receiver to reach your eye.
The opacity of that plastic is not from a pigment, it is from the bandpass characteristics. The plastic is opaque to the visible light spectrum. That is its purpose. It passed IR and blocks visible light, so it looks "black".
An IR illuminator behind it, and an IR camera in front, would make it look transparent.
If this was not the case, the detector embedded in it could not operate.
28,160
If you look at that sensor with an IR viewer scope, as I have done, you will see right thru it, just as I have done! It is not really black it just looks that way because it blocks visible light.
Seeing and thinking that you can believe what you see is often an error. The human eye is easy to fool.
DC_Kid
Joined Feb 25, 2008
1,242
With the right tool, you can see right through aluminum.
But "black". So where does all the visible light energy go if it's not being reflected?
Is the IR receiver (the plastic) bandpass or lowpass filter?
k1ng 1337
Joined Sep 11, 2020
1,038
It's obviously limited by its visual bandwidth.
Some species of animals and insects can see further into the ultraviolet and infrared than we can.
I watched a very interesting documentary where they took cameras of different bandwidths into the jungle and watched how certain species interacted with plants. The attractive "colours" of flowers towards insects was especially cool. It's literally a different world for these creatures and the evolutionary mechanisms at work are incredible to witness which was previously impossible to see before technology. The sensory organs of some species will blow your mind.
https://en.m.wikipedia.org/wiki/Evolution_of_the_eye
Check out this article, humans are fairly primitive compared to what some species can detect. And it doesn't stop at sight, birds can detect magnetic fields and sharks / snakes can "smell" in the parts per million range. Incredible.
28,160
If you have ever used an IR scope then you might consider that if IR was also visible to us everything that we see would be so very much different and our visual sight would be rather overloaded. Like when you can hear 50 people talking all at once, and not understand very much of it.
38,754
it's being absorbed like a black body.
In this case it's a black body for visible light, but transparent to IR.
That's rather the opposite of window glass which is transparent to visible light, but absorbs/blocks IR.
