Why ID_max is lower than ID_on?
schmitt trigger
Joined Jul 12, 2010
2,085
What this means is that if you have a Vgs pf 4.5 volt, and manage to operate the Fet linearly such that you can maintain a Vds of 10 volt, you could get a drain current of 600 mA.
Of course, at those conditions the poor FET would be dissipating 6 watts, which would almost immediately burn your device.
That parameter is there to show you the device's transconductance. It is not an operating parameter.
OBW0549
Joined Mar 2, 2015
3,566
Can you explain to me why ID_max_pulsed is lower than the typical value of ID_ON?
The former spec is an absolute maximum rating beyond which you risk damaging or destroying the device; while the latter is a performance characteristic indicating the typical behavior of the device.
Jony130
Joined Feb 17, 2009
5,598
But what is the point of a typical behavior characteristic if I cannot use it in real life?
schmitt trigger
Joined Jul 12, 2010
2,085
You can use typical values if you know how and where to apply them.
For the “how”: apply the derating factors like temperature and SOA, to the typical values.
For the “where”: if this is a single personal project, you can use the typical values.
If in the other hand this is a mission critical device, whose failure could lead to loss of property or life, then you should use the worst case values and add some additional margins.
