Why did my LED driver blew up?
muno94
Joined Oct 11, 2017
8
Greetings. Recently I bought a LED light for AC 9-18V for my moped. It uses AC which gives about 9V when at high rpm.
I installed this LED light. It worked fine for the first 15 mins. It dies out suddenly after. Opening the driver I noticed that one of the diode has blown up and two of the capacitors are swelling. There seems to be some liquid around the driver (it is not water as it was still there even after few days)
I have bought 2 of these LED and both ended its life after 15 mins or so. Why does it happen? Is my bike giving too much voltage?
WhatsApp Image 2017-10-12 at 11.46.31 AM.jpeg 047493ca-befb-4e1f-8862-c245803aca05.jpg WhatsApp Image 2017-10-12 at 11.46.30 AM.jpeg
muno94
Joined Oct 11, 2017
8
Welcome to AAC!
Probably. Does it have a voltage regulator?
Thank you for the warm welcome Alec! the bike itself or the led driver? As for the led driver, the only components that I could identify are
- 2 copper windings
- 4 470uf 25v capacitors
- SS34 diodes
- SMD resistors
I dont see any voltage regulators like the LM7805
dendad
Joined Feb 20, 2016
4,641
It does look like over volts from the bike.
They usually rely on the headlight drawing enough current to keep the volts down. And if they have a voltage reg, the power is still often very spikey. The LED lamp probably will not draw enough current.
A voltage regulator looks to be needed.
Can the lamp run on DC? If so, add a rectifier and capacitor circuit along with a 3Amp EBay DC regulated power supply board to drive the lamp. Or a power Zener made with a power transistor and Zener diode and resistor all inside a 25A bridge rectifier so it will clamp the AC from the bike alternator to a safe level, like 12V or 15V.
muno94
Joined Oct 11, 2017
8
Im actually on a project to covert the bike's AC to DC now. I've found a link where someone has done it without having a voltage regulator. Thank you for the suggestion :)
I'm a little baffled at how the LED which could receive 9V ~ 18V died when my bike barely gives out 9V. It is usually lower (4V ~ 6V). at lower rpm
muno94
Joined Oct 11, 2017
8
The bike.
How did you meaasure the voltage? An inexpensive digital multi-meter doesn't give accurate AC readings unless the waveform is a pretty good sinewave.
I don't think the bike has a voltage regulator as with normal halogen bulbs, the brightness of the bulb varies with the engine RPM
Unfortunately an inexpensive digital multi-meter is all I have.. So I can't say for sure
ian field
Joined Oct 27, 2012
6,536
Welcome to AAC!
No idea what they use now - but in my day. the battery gassing expended enough energy to 'control' the voltage when the main beam wasn't being used. Some have a series pair Zener module to clip the AC output. cheaper models usually switched in a ballast resistor when the headlight was off.
Half wave rectification is/was the norm for the DC parts of the system - its not at all like a well behaved bench supply.
ian field
Joined Oct 27, 2012
6,536
It could be. I wish I had an oscilloscope to further investigate it.
Identify the ignition part before worrying too much about spikes. the old energy transfer ignitions were totally separate from the lighting etc and DC circuits. CDI with a high voltage winding on the generator became popular, they're also separate. starter solenoids and indicator relays can generate spikes, but those events aren't easy to sync a scope to.
In your OP, its not crystal clear what's AC - you're not stuffing AC generator into a driver module that expects DC are you?!
Even an AC module would be expecting 50 or 60Hz - you need to find out how many poles and the generator has and calculate frequency from expected RPM range.
I'm kinda thinking towards a buck/boost converter charging 7 or 8 nickel chemistry cells.
muno94
Joined Oct 11, 2017
8
My bike uses fuel injection. I can get DC from the dash/gear wiring but then I wouldn't be able to control hi/low beam
The AC is from the H4 female plug
Alec_t
Joined Sep 17, 2013
15,124
I don't see how the circuit in post #14 can work. What supplies the power, and where does it connect?
You're no doubt aware that on most motorbikes/mopeds the AC generating coil has one terminal grounded inside the magneto? That, and the fact that the common terminal of the bulbs is also grounded, make conversion by full-wave rectification to DC tricky.
muno94
Joined Oct 11, 2017
8
Initially I was afraid of discussing this because IIRC it is against the rules but..
The circuit works fine. It manages to give a constant power that lit up a great beam on the LED
The right side is from the bulb plug and the left side is the LED
However using that configuration, even when I take off the low beam source on the right side, the circuit will lit up both high beam and low beam. I am guessing because the ground is connected at the same wire on the High beam rectifier, thus providing power on the low beam LED as well
