why are two op-amps required in some circuits if one op-amp can provide high gain?
ronv
Joined Nov 12, 2008
3,770
I'm trying to make my own rfid reader based on this:
http://www.serasidis.gr/circuits/RFID_reader/125kHz_RFID_reader.htm
But what I want to know is why are two op-amps and a transistor necessary? Couldn't one get away with one op-amp and a higher negative feedback resistor value and still achieve the same gain? or is there something I'm missing?
The transistor makes sense because it squares up the signal from the first op amp. The second one doesn't work at 125 Khz because it saturates, so won't switch that fast.
Papabravo
Joined Feb 24, 2006
22,116
In circuit design: gain is not the only consideration. There can be a list of reasons for using two amplifiers as long as your arm.
38,952
Generally it's not just the circuit gain that's important, there's also the circuit bandwidth.
Each op amp has a bandwidth equal to its gain-bandwidth divided by the closed-loop gain.
Thus two opamp in series with the same total gain as one op amp will have twice the bandwidth.
BR-549
Joined Sep 22, 2013
4,928
It's because of different transducer outputs and the required signal inputs for processing or transmission.
Some transducers output a current and some output a voltage. And because of signal characteristics....we might need to convert the current to voltage....or convert the voltage to current.
One might need to select (tune) a particular parameter. And as mentioned, one might need to filter more than one parameter(band) also.
bertus
Joined Apr 5, 2008
23,042
I would not agree with this.
Take this example:
1 opamp GBW 1 Mhz gain 100 will result in an effective bandwith of 1 Mhz / 100 = 10 Khz.
2 opams with each GBW 1 Mhz gain 10 will result in an effective bandwidth of 1 Mhz / 10 = 100 kHz.
As there are 2 opamps used the total gain is 10 X 10 = 100.
Bertus
