which will be better linear IC circuit or SMPS?
rahulb
Joined Jun 5, 2019
44
Hi Everyone,
I am designing a blinker for led strips.
please check the design below :
The 4017 ic resets after three counts.
The timer 555 and 4017 circuit is powered by 9v supply and the mosfets are powered by a 12v, 2 amp supply.
My question is about the 9v supply. Which type of supply will be better to power the blinker part of the circuit using 12v 2amp smps supply which I am using for the mosfets.
1. A linear circuit probably with LM317.
2. A buck converter
3. or a simple voltage divider circuit?
thanks
AlbertHall
Joined Jun 4, 2014
12,654
Forget the voltage divider, that isn't going to work.
If you feed the LM317 from the 12V supply it will not use much power compared to the LEDs and will do the job.
You could use a buck converter but in this case I don't think the extra cost and complexity would be justified.
Irving
Joined Jan 30, 2016
5,195
LM317 or LM7809 will work, the current draw of those ICs is so small that the loss savings don't justify the additional cost of a buck converter.
A voltage divider or better, a shunt regulator with a 9v zener or a TL431 would work.
But why not run the CMOS off the 12v as well?
What was behind your choice of MOSFETs?
rahulb
Joined Jun 5, 2019
44
hi,
when I am using 12v for the blinker circuit. the mosfets are not switching on and off.
I chose mosfets according to availability. I needed a mosfet which can run on 12v and can be used for 2 amps current.
one question:
If I use 7809, will I need to use resistor before it as the smps power supply is 2 amps?
thanks
AlbertHall
Joined Jun 4, 2014
12,654
No, it will only draw whatever current it needs to feed the logic.
Incidentally, it would be better to connect the MOSFET sources to ground, and connect the LEDs between the drains and +12V.
Are the LEDs designed for 12V?
rahulb
Joined Jun 5, 2019
44
hi,
thanks for reply.
actually there are three strips of red, green and blue. they share a common neutral. yes, they are designed for 12v, I calculated resistor for each strip.
thanks
djsfantasi
Joined Apr 11, 2010
9,237
hi,
thanks for reply.
thanks
If they are designed for 12V operation, I suspect that the strip includes current limiting resistors. Why did you add another resistor?
AlbertHall
Joined Jun 4, 2014
12,654
In the circuit that you show, with the logic powered from 9V, you will get a good bit less than 12V across the LEDs, probably about 6V.
djsfantasi
Joined Apr 11, 2010
9,237
Isn’t the IRL840 an N channel MOSFET? The circuit shown uses them to switch +12V. He needs a P channel MOSFET and driver that can switch with 9V.
I may be wrong...
eetech00
Joined Jun 8, 2013
4,734
Hi
The circuit should work with the mosfets you have, but you have the mosfets connected wrong.
Connect the source to ground and the drain to the LED-, LED + should go to +12v (so the load is connected between the drain and +12).
You don't need the regulator. Run the entire circuit using a 12v supply.
Connect a bypass cap (0.1uf) across the power supply pins of the 555 and the 4017
djsfantasi
Joined Apr 11, 2010
9,237
Hi
The three LED strips are connected together with a common cathode. They aren’t independent strips. Thus the TS can’t switch ground as you suggested. Hence, different (P channel) MOSFETs are necessary.
Dodgydave
Joined Jun 22, 2012
11,395
Hi
He's switcing Positive supply to Common ground loads, so your idea won't work, he needs Pfets.
