Which voltage to use when calculating Current
pprendeville
Joined Nov 19, 2009
15
Hi all,
Just want to find out which voltage I should use when calculating the current through the 5 ohm resistor in the pic. Originally I thought it was the supply voltage, 20V but according to the notes it says to use the voltage drop across the resistor, i.e. 9.1V.
Why is this so?
Jony130
Joined Feb 17, 2009
5,601
Well
V=I*R;
I=20V / (5Ω+ 12|Ω|18Ω||9Ω+4Ω||4Ω)=20V/11Ω=1.81A
So voltage on 5 ohm resistor is equal
V=1.81A*5Ω=9.09V
mrmount
Joined Dec 5, 2007
59
That is because the supply voltage 20 V is across the total resistor combination and not 5 ohm resistor alone. See Jony130's calculation.
