Which type of Motor would be best to use (with speed control) for RPM range 200 to 2000 with a torque more than 0.8N.m
suji_03
Joined Jan 3, 2024
5
I am looking for a motor which can run from 200 RPM to about 2000 RPM with a torque more than 0.8 to 1 N.m. The problem I am finding is that it is hard to find a high torque motor with this RPM range. What would be the best solution for this?
Should a BLDC motor do the trick. But also I don’t want to design a speed controller.
27,361
INDEED! an adequately sized brush type motor will deliver that range, and only need an adequate DC voltage supply to set the speed. The speed will vary with the torque required, but with an adequately sized motor the change will not be a lot.
One caution is that at the slow speed and high torque the internal cooling fan will not provide enough cooling air.
schmitt trigger
Joined Jul 12, 2010
2,056
No need to design anything. There are many DC motor speed controllers available on all of the usual (Amazon, Ebay, Alibaba, etc) online stores.
27,361
There are also much better products available from honest sellers who are able to provide customers with useful customer support staff. Including not a single one of those listed above.
PointTwoPA
Joined Jan 28, 2021
see Maxon for DC motors, gearheads, and speed controls.
You'll have to search the site with your specifications:
https://www.maxongroup.com/maxon/view/product/gear/planetary/gp26/406762
