A new type motor/generator development
Status
Not open for further replies.
Lemi çağlıbektaş
Joined Feb 8, 2018
6
Before opening the subject, I would like you to know that the subject is an electrical machinery course and electrical engineering infrastructure is required to understand the subject.
In order to be even more explanatory, rather than giving a lesson about whether the information needed is known or not, I will briefly ask you to watch the YouTube video I have given the link below, which is more or less able to clarify the subject I found on Youtube and has sufficient theoretical information.
Because I don't know what you know and what you don't know :) please follow the video to the end.
Of course, if you watched the video, we can continue from this part, now, as you know, please imagine that this structure that we are talking about as a linear shaft motor or generator, and the cvt chain, the link of which I share below, forms a structure by passing through the coils.
Of course, this chain should be thought of in such a way as to form a structure with pulleys on both sides, I think you will understand what I mean when you see the drawing I prepared in Pdf form.
As a result, I would like to be able to work together for the new type of motor / generator that I am developing, I cannot continue due to financial impossibilities on issues such as simulation and prototypes, etc. that I need, I am sure that you will take the issue further. It is also obvious that the subject should be considered in depth and that he wants academic work.
Sincerely,
28,415
Given that I have actually had training relative to linear motors, as well as some understanding of magnetic principles, I can advise the TS that creating a linear motor/generator with that level of efficiency would be a great benefit to much of humankind. Generating some voltage by passing a magnet thru an insulating material tube is usually an interesting thing, and the physics of it are well known and totally reasonable, but seldom is it highly efficient, although it can be very useful.
So PLEASE Describe the design with the much higher efficiency!!
Lemi çağlıbektaş
Joined Feb 8, 2018
6
If it is going to be developed only as a generator and permanent magnets are going to be used instead of residual magnetic silicon sheet packages, I recommend the Hallbach array.
If the coils are wound with a winding technique that is only possible in 3D printers, the magnetic field created can be increased approximately 3 times.
Lemi çağlıbektaş
Joined Feb 8, 2018
6
Oh, don't get me wrong, I'm not asking for money from anyone, I'm retired and I also work, I gave the examples on YouTube because I thought you could understand the theory better visually, otherwise you can find a lot of scientific articles when you search the literature for linear shaft motor. My aim is to open the subject to someone who has the infrastructure needed for the project, such as simulators, etc., and create a product that can be beneficial to humanity, after all, I'm not a scammer, I'm a science enthusiast, these reactions made me very, very sad.
Status
