Which part in the LCD TV power circuit gets short?
XiQueming
Joined Nov 28, 2017
18
Voltage regs are worth repalcing, I deal with a lot of power supplies where faulty capacitors overload the regs and cause them to fail.
Sorry, these days I am busy with the other things. I will report all the measurements later. What you said is right. I guess the Voltage regs are that two transistors which mount on the heatsink. Please check my photo.
XiQueming
Joined Nov 28, 2017
18
SNPS.JPG SNPS.JPG I am not sure that two transistors are Voltage regs.
Since TV's power supply is Switch Mode Power Supply, my TV starts clicking as soon as I plug the TV into the power, does that indicates the IC chip is bad
XiQueming
Joined Nov 28, 2017
18
P1.JPG I tested (2), only got 120V AC, unable to get 250V as the board says. I test (1), it supposes standby 5.1 V, the reading was very unstable, from 2,3,4,5, and kept rolling.
