Which LGA or breakout option is best for testing a SIM868 module?
ali. s. r
Joined May 17, 2024
I want to test a SIM868 GSM/GPRS + GPS module, but I’m not sure what the best approach is for connecting it temporarily without permanent soldering.
  • The module I have is an LGA version (surface-mount).
  • I want to avoid soldering directly if possible.
  • I’ve heard about LGA sockets, breakout boards, and pogo pin adapters, but I don’t know which is most practical for testing.
Which method would you recommend for safely testing the SIM868 module, especially if I want to connect it to a microcontroller for experimentation?
Thanks in advance!
ronsimpson
Joined Oct 7, 2019
4,805
Are you wanting to socket this?
Pogo pins will work but I don't think there are any small enough.
I have worked with companies that make sockets, but their prices are high.
One method I used: We made a PCB with the matching footprint. But you can't reliably just push the two together. There is a company in Japan that makes a soft flexible piece of rubber that is about 1mm thick. It has millions of vertical wires hidden inside. It makes a reliable connection from the Device Under Test to a PCB. I can't remember the companies' name now.
